Dead birds are not uncommon. If you want to repair your AC as a DIY it is doable, but it is the pickiest repair to do. You've air and water in your AC freon loop meaning seemingly unrelated parts have to be replaced. Replacing them is easy, knowing to replace them is the trick. You will need a special tool, a vacuum pump to repair the AC. About a hundred bucks or so if you shop around.
2003 S manual
