Old 08-20-2015, 11:29 AM   #26
epapp
epapp's Avatar
What causes the engines to have the highest load on the valve train at idle???? I don't buy that for a second. you're telling me my 5 timing chains, IMS shaft/bearing and cams/valves are under less stress and load when I'm WOT going through all gears at 5k rpm? The only thing I can think of is the chain tensioners and variocam. Still doesn't make any sense.
The second sentence of Jakes is inherently true of any moving part requiring oil, and mostly just a statement. If I'm not mistaken, the moving parts DO get a constant flow of oil, EVEN at idle...unless the oil pump just decides to take a break < 1000rpm...
I know Jake has a lot more experience than myself with these engines, but this doesn't make sense to me.
epapp is online now   Reply With Quote
