Paint correction is only best left to the "experts" if you are using a rotary. If you stick to a DA, a mild cutting compound and do the least possible cutting to get results then you will save yourself a fortune over what an expert will charge and get 95% of the results. If you stick to the recommendations I linked to earlier there is no chance of burning your paint or leaving swirls and the results are excellent. You tube search the name of the kit I linked and watch the instructional/demo videos before you write off paint correction as beyond your abilities.
02 Seal Grey 5 Speed
