Old 08-19-2015, 06:16 AM   #11
jaykay
jaykay's Avatar
Yeah....I had my carpet off and man that firewall gets pretty toasty. Has anyone put insulation/gold leaf on the backside of the hatch...? If my engine comes out I think I might foil up the whole engine bay.
Back on topic: Assuming that engine oil cooling is the way to go ( for a dedicated track car: transmission?), I had envisioned a duct incorporated in the right side vent that directs cooling air to shrouded oil cooling heat exchanger. If there is enough room you could put in a duct for the trans. as well.
You would fashion an opening the side vent shroud to accept a bell mouth / velocity stack with a duct leading to the shrouded oil cooler. I think setrab makes some small stuff that may fit in the engine bay and I believe I have seen them used for Boxster trans coolers.
With this arrangement you would get a seamless cold air intake for oil cooling. The engine bay fan along with ram air from the side vent would provide for superior heat exchange.
Not sure about how to properly mount the heat exchanger in the bay....without welding mounts. Unfortunately all this may have to done with engine out
986 00S
