Originally Posted by JayG
Nice shot Tim
Daddy paid way to much money for (assuming anything he says is actually true) and according to another post needs $9000 of repairs including tires!
Things are just not adding up, if he actually has any money, only a moron would spend it the way he is claiming.
Lets burn money
Bro stop being mean.
All I can tell you is that I have the most meticulous perfect maintenance base Boxster on this forum.
You buy tires because you have to, I buy tires because I want to. I did not do that at the dealer,.
On the dealer I put stainless steel brake lines, Oe rotors and pads, flush brake system. all new filters, cabin engine, a/c oil. It uses so much oil. New engine and transmission mounts to new spec.
New arms in front and rear to modern spec. It's aligned with new tranny fluids and suspension damped to spec.
I'm here because after I received the car like this I understood the concept of the dealer and the car was totally different.
The 6k was not even counting the new 2 keys I bought and the money that I will invest in a turbo stage 2?
Great experience [emoji4]
