Is it possible you left some bolts loose (e.g. caliper bolt)? I assume it would make a nice click if it has some play.
You might not need to worry about that sound though, because if it is the caliper bolt you'll be dead anyways!
...joke..but the first thing I would look for is an ill-seated pad in the caliper or any loose bolts as a result of the brake work.
