Old 08-17-2015, 11:46 AM   #2
newBgeek
The noise is likely coming from the expansion valve. It's located under the front hood next to the battery compartment. Remove the lid for the battery compartment, then remove the cover on the passenger (right) side of vehicle. You'll see a small rectangular expansion valve. Put a screwdriver on it then put your ear on the screwdriver to verify the noise.
Mine made a noise too but it's lessened after running the A/C non-stop for several hours. I guess the previous owner didn't use the A/C much so all the seals dried out.
newBgeek is online now   Reply With Quote
