Old 08-17-2015, 08:19 AM   #1
JayG
On the slippery slope
JayG's Avatar
Originally Posted by hancock1701 View Post
Can you explain please explain how you would use it dry? So you have a quick disconnect between the Motive tank and the reservoir. When the tank is still pressurized, you quick disconnect it, open up the reservoir, add fluid, replace cap, then quick connect again?
Yup, that's how you use it dry
You do need to make sure you done run out of fluid in the reservoir, or you will need to re-bleed the entire system
It does save on having to clean the motive
2004 996 Targa Tip
Instructor - San Diego region
