Old 08-17-2015, 09:07 AM   #2
hancock1701
Originally Posted by Deadeye View Post
Hi Rick, I open the bleeders apx 1/2 turn for a quicker job. I also use the power bleeder dry and just add fluid into the reservoir as I go. I also put a quick disconnect in the hose between the Motive tank and the MC reservoir so I don't have to pump it up every time I add brake fluid. 20 psi works well for me in the tank
Can you explain please explain how you would use it dry? So you have a quick disconnect between the Motive tank and the reservoir. When the tank is still pressurized, you quick disconnect it, open up the reservoir, add fluid, replace cap, then quick connect again?
hancock1701 is offline   Reply With Quote
