Old 08-17-2015, 03:43 AM   #1
Dremzy
Apologies,
Ok so since replacing the multi function switch, when selecting P or N or R the red light on the dashboard shows solidly (meaning no blinking). The D light still blinks when you switch to 'D'rive mode on the selector.
When using M mode you can switch gears using the steering wheel buttons however the dashboard still blinks 'D'. All gears shift correctly at the right RPM in both manual and auto mode.
Using a diag tool, when trying 70mph on the motorway the tiptronic temperature is reading 196F, is this too hot??
Please be advised that the multi function switch solved the fault in the system and PST no longer shows any fault in the tip (p708)
Dremzy is offline   Reply With Quote
