Old 08-16-2015, 10:33 AM   #12
particlewave
Originally Posted by Muzzle of Bees View Post
The key should manually unlock the door. Then, one trick that works is to place a battery on the drivers side floor. Connect the positive to the fuse box per the instructions, ground to the steering column. Close the door. Unluckythe car using the remote. This should work. It is some work though.
NO. You aren't even addressing the problem, but the locks are electric anyway, so double wrong and no gold star for you.
