The key should manually unlock the door. Then, one trick that works is to place a battery on the drivers side floor. Connect the positive to the fuse box per the instructions, ground to the steering column. Close the door. Unluckythe car using the remote. This should work. It is some work though.
2016 4Runner TEP
