Old 08-13-2015, 07:24 PM   #132
Pdwight
Pdwight's Avatar
I think I solved my problem
I put some play back into the end bearings...not much just a tiny amount. I then used three 1/4 inch washers on the front two studs and 1 washer each on the back two studs of the mounting bolts for the shifter. This gave a slightly front up a tiny bit and moved the cables a bit further away from the "hump"
I took her out tonight and the shifting was much better than before
