Old 08-13-2015, 02:21 PM   #3
JFP in PA
Originally Posted by evan9eleven View Post
Awesome Jeff, thanks. Turns out my Indy has Durametric Pro (I didn't know before heading to the dealer that the pro version would code or that my Indy had that version) so I hope it works. Anything you can think of that might actually be hindering the coding by the way?
Not sure why the dealer accepted the job and handed me paperwork clearly stating the work to be done and then spent over an hour of shop time on it if they had an issue with actually doing the work. FWIW this is a Spanish dealer and not the USA, not sure if that makes any difference. I was treated with respect from start to finish and they didn't charge me anything.
The only thing that would prevent activation is an incorrect connection on how the stalk & wiring was installed. If you are absolutely positive it is all correctly wired, it should be a simple process to activate it.
