Thread: Bagged Boxster
Old 08-12-2015, 02:45 PM   #22
nathanmoutlaw
Hi,
i found this on youtube: https://www.youtube.com/watch?v=vD7IIbtBSVU
Think you will run into different problems if you really want to slam the car, because of the axle and trailing arm construction. Also as mentioned before the underbody is completely dressed up with plastic elements to improve air flow. So if you get too low there wille be a lot of damage. Think this will be a challenging project.
Regards from Germany
Markus
I would be driving it close to stock height to keep the damage to a minimum. That's the only reason I am not doing a static set up on this car. Only to be parked and slammed.
nathanmoutlaw is offline   Reply With Quote
