Old 08-12-2015, 07:53 AM   #1
spendy
Originally Posted by BOOTLEG View Post
I was most interested because I am considering buying a used 3.2 off Ebay. When shows up, that lift point would make it really easy to move it. So they are installed on all 3.2L engines at the factory?
Keep in mind the pictured lift point is at the rear of the engine, so it is not balanced at all. It also doesn't look real strong to me. As mentioned, it is intended to be a way of supporting the rear of the engine while pulling the trans. You will need to come up with a front lift point, so you can lift at front and rear, to lift the engine while keeping it level. I attached to one of the bolts that holds the front engine mount, although the lift chain put some stress on the front of the pulleys - probably not ideal.
spendy is offline   Reply With Quote
