Thread: Bagged Boxster
Old 08-12-2015, 12:04 AM   #15
sickbananas
I don't believe there is a 'kit' avaliable for the boxster, I could be wrong. Most air suspension brands/suppliers offer a universal kits for cars that aren't catered for off the shelf. These kits needs to be welded up according to what you need so that the set up can be bolted into the 'oem' position and use oem mounting holes etc.
The supplier would need the oem setup measurements and some photos to supplier you with the appropriate universal kit and air bag combo. Also be careful as not any air big should be used, it should be spec'ed car specific due to weight etc.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
