Originally Posted by Miata2Boxster
I did a complete check for shorts and found none. When I unplug the CLU, C3 fuse does not blow. As soon as I plug back in the CLU C3 blows. The Jack a&& prior owner left the CLU unmounted and dangling....seems to not be original either. He must have got a used one and stuck his hand under the seat to make the switch.. When I opened it I found no apparent moisture or corrosion on the circuit board. I guess I will get another and see if it does the trick after installation.
Do I need to have a code to install if I don't use my remote locking function from my keys?
I know this is an old post, but did you ever resolve this? I'm having the exact same problem. I hope you have the solution. I switched out the CLU with a re-programmed one and it's still blowing the fuse. I'm hoping the box is good and it's something else that's a minor repair. I paid $495.00 to have the box repaired or I should say replaced with a rebuilt one, but they did say may old circuit board was bad and non-repairable.
Joe
