Old 08-10-2015, 11:00 AM   #4
JFP in PA
Originally Posted by epapp View Post
My LN oil plug is leaking from inside the hex drive, meaning it has a crack or something up in the hex cutout where you put the allen to tighten the plug. I know it is from the inside because I cleaned the area 4 times and watched the oil gather from inside the plug.
Has anyone else ever had this happen?? Its a slow leak but will produce about 10 drops of oil over night sitting still with cold oil...
You will see this in plugs that have been over tightened, cracking them. When you get your new LN plug, be sure to not over torque it (19 ft. lb. is the correct torque for this plug).
