Old 08-10-2015, 08:42 AM   #3
JAAY
JAAY's Avatar
You have to re-bleed the brakes and clutch. It is all one system. Best to use a power bleeder like the motive. Here is a step by step process. There are 2 bleeders per caliper and you do the clutch last. I hope this helps. Good luck and report back after you have fixed it. Porsche Boxster Brake Bleeding - 986 / 987 (1997-08) - Pelican Parts Technical Article
JAAY is offline   Reply With Quote
