Old 08-09-2015, 05:13 PM   #16
KevinH1990
KevinH1990's Avatar
Is it possible that there is a defect in the headunit? (The only way I can think to check that is to swap in a different unit.)
There are some differences between the 2000 and 2003 Boxster audio systems, and I don't think I can apply my experience directly to your conditions. I guess if I ran into the problem you have, I would check for a loose wire before I swapped the headunit. Did you solder the connections or use crimp connectors?
