Old 08-05-2015, 03:10 PM   #11
Mr.JonathanLanda
Originally Posted by epapp View Post
Using the proper gauge wire, find the correct traces in the bulb carriage and solder them together. There was some funny business when switching to LED bulbs involving swapping power and ground traces(I think?). Sounds like you won't have to worry about that.
Did you ever figure out the year of your car?
Mod done,
I will put electrical tape around it. Also changed the rear fog light bulbs to the smaller one so the light looks even.
So to complete this mod is to:
Disconnect the cable 5/ gray and white. That is for the pull action of fog light
Connect a wire from 1 (far left black and gray) to 5 the one disconnected.
That way I will use the 2 pull fog light switch will be for the white neon under glow just to play around hehee
Mr.JonathanLanda is offline
