Old 08-04-2015, 01:24 PM   #1
shacky
Shacky
Originally Posted by BFeller View Post
Start looking for them with the top up. It will not be easy, but if you start looking through the rear window and figuring out what is what - you can tell if they are detached. You want to make sure that they don't poke a hole in the foam drain pans under the top assembly. Holes in them can allow water into the interior.
How do I fix drain pans if they did?
shacky is offline   Reply With Quote
