Old 08-04-2015, 07:22 AM   #1
BFeller
Start looking for them with the top up. It will not be easy, but if you start looking through the rear window and figuring out what is what - you can tell if they are detached. You want to make sure that they don't poke a hole in the foam drain pans under the top assembly. Holes in them can allow water into the interior.
