So I went on a two week holiday and left the 986 in the garage.Home today so I went and started the car as it hadn`t run for a bit. Dead cold ran for a few minutes.Turned it off and tried to remove the key...no luck. It ran for maybe 5 min went through the gears in M and A parked and tried to put in in P. Indicator flashed R and something I didnt see in the past was in D the light was blinking. Anyway put in in the garage. Engine would turn off but all the lights radio etc stayed on and couldnt remove the key.So I disconnected the battery. Tried the key and it came out like a new one and the steering locked as it should. With the ignition switch not energized it works fine. Might this problem be the electrical part of the ignition switch ?
