Thread: Oil Starvation
Old 07-28-2015, 10:29 AM   #10
Qmulus
inveniam viam aut faciam
Originally Posted by Fyeganeh View Post
I assume you mean the root problem is many oils losing viscosity at high temps whereas Driven DT40 and the xp9 racing oil not doing so. I believe you don't think it has as much to do with lateral g-forces. (I have switched to DT40).
But my question is in a 15 year old car does the piston actually wear out/break and need replacing so as to prevent damage? Is it designed to last 15-20-30+ years?
Thanks,
Fred
The piston doesn't wear out, but the original is more prone to jamming in the bore, leading loss of pressure than the updated replacement. The question is whether the piston jams in the bore, resulting in bearing damage, etc., or if debris going through the oil pump and through the oil pressure regulator (relief piston), causes it to stick.
Qmulus is offline   Reply With Quote
