Old 07-28-2015, 09:08 AM   #4
JFP in PA
Originally Posted by Boxster33 View Post
Hi All, I have a 2000 Boxster S with 43,000 kms. Went for a drive the other day when the check engine light came on. Durametric software shows fault code:
Current Fault Codes
P0154:
Porsche fault code 18 - O2 sensor ahead of cat. conv. Cylinder (4-6)
Is this code indicating that the 02 sensor before the CAT should be replaced on the drivers side? The one closet to the muffler?
Is this the correct part?
2000 Porsche Boxster S Convertible - Exhaust Pipes, Manifolds & EGR - Page 1
Thanks in advance.
P0154 indicates a signal loss from the sensor. While it could be the sensor, more often it is a connector or wiring issue causing the interruption.
