Thread: V8 Conversion
Old 07-26-2015, 10:22 PM   #13
martsink
Many people will tell you that the stock throttle pedal/cable will not work for the V8 swap, but what most of these people don't know is that the early Boxsters came with a full cable setup (no drive by wire). I purchased mine from a 986Forum member with a pedal for $50. The cable length is great and the TB travel is spot on. Today I made a custom bracket to hold the cable in place. The clamp that comes with the wire can be attached to one of the intake manifold bolts to hold it in place. The end of the cable has a metal sleeve that flares out at the end towards the TB. I used small metal plate to wedge the flare to the bracket (you can see it below held by two stainless machine screws).
martsink is offline   Reply With Quote
