Hey guys! I haven't really had time to make detailed updates recently. We spent the last couple of weekends working on my friends 2005 E46 320. Dropped in a 330 engine and also changed one of his wheel bearings and an axle boot. In the process, we noticed that his rear subframe mounts are cracked, so this weekend we will be welding up the cracks and reinforcing the body. He also got a set of poly bushings to replace his old ones while we are at it.
The work on the Boxster is progressing nicely. The fuel lines and fuel regulator are installed, the brake vacuum line is hooked up, the stock throttle cable (from early Boxsters) is hooked up and working perfectly with no modifications, the harness is 90% finished, the alternator bracket is finished, the starter motor has been modified to fit. Next week I will be getting some parts to get the PCV valve installed, and hopefully the necessary parts to finish the intake and cooling systems.
