Thanks for the advice. I've been siting here with the car running for about 45 minutes and drove it around the neighborhood to warm it up. I left the bleeder valve open but didn't notice anything from it. The fans on the radiators and engine bay have been cycling on and off and it has been up to temp for a while and nothing is happening. I noticed the drivers side fan didn't come on while the passenger side was on low speed. But they were both on when the fans were on high speed. Not sure if that's normal. I marked the coolant level a little bit after starting up and it's only moved maybe a couple millimeters. Hoses all look okay and dry from the engine bay side and in the trunk. Any ideas?
