First thing you learn is there is no such thing as a cheap Porsche.
You'll pay for it one way or another.
That said, you can definitely do most of the work yourself.
The clutch kit you can purchase online relatively inexpensively.
I did something very similar after buying my S (clutch, IMS, RMS, chain tensioners, plugs, tube, trans fluid, and oil change). I knew it needed all this up front.
Believe it or not the hardest thing for me was installing the RMS to the correct depth. Took me 3 tries (should have just made a tool and been done with it).
