Hi,
Check all fuses and relays. Could be anything really from ignition switch to batery cables or worse. You could try disconnecting the Battery (Radio Code in hand) and leaving it off 5 min or so. Then reconnect it and this should reset everything, it's cheap and may work. Try this first, next... AAA?
Happy Motoring!... Jim'99
