Thanks for the tip, I took the seat out yesterday to look at it and again today without removing the seat. It was pretty easy without removing the seat once you've had it out and see how it's mounted. Still no luck though, it did look like it had some water damage underneath the circuit board. I'm taking it to work tomorrow and see if one of the biomed guys can take a look at it, I know nothing about electronics. I'm not even sure if that's the problem, but it's a starting point, the C3 15 amp fuse keeps blowing as soon as I put it in or turn the key in the ignition.
