Old 07-19-2015, 11:53 AM   #1
particlewave
Originally Posted by mountainman View Post
no problem,. $25 ignition switch and 45 minutes of your time.
Originally Posted by patssle View Post
I'd say 20 minutes. It should be a maintenance item...just replace it before it leaves you stranded!
You guys should check the dates on the posts because it looks like your both replying to the original post which is 2 years old.
Jaykay seems to have a mechanical issue. Replacing the ignition switch won't fix that.
Jay, replacing the lock mechanism is more involved (definitely not a 20 minute job), so you may want to address that soon.
If it is a mechanical issue, which it sounds like if you have side to side play, you'll need to take it out to see what is causing the issue. It may be the mechanism, lock cylinder, or both.
