Old 07-19-2015, 11:21 AM   #11
AtlantaBoxster
Originally Posted by healthservices View Post
okay so you and I are on the same page, yes...
- Brown wire to small Black/white wire on right side immobilizer
- Brown wire to small Black/green wire on right side immobilizer
will show voltage when nothing is happening.
when you ground this wire (make sure the door latch thinks it is latched by using a screw driver and flipping the latch.) when you ground one of these wires the door will lock or unlock.
This is what your aftermarket door module is suppose to be doing, supplying a momentarily ground to each of these wires depending on if you are locking or unlocking the car
when you use a voltmeter the voltage should go to zero momentarily when the lock button is hit.
Ok. Heading back out to try the next steps. It's hot here in Atlanta. BTW, what is this immobilizer you speak of?
AtlantaBoxster is offline   Reply With Quote
