Hey Coffinhunter; I'm going to go with a bad headlight switch. These i'm sure you're aware are a common failure item. One thing that was identified in another post by a resident electrical genius (Particlewave) is that these switches have full electrical current running through them versus controlling a relay, therefore making it easy to understand how they can corrode and/or burnout. Since the headlights are used most they will also fail first.
edit: since I see you have switch in parentheses I know you're aware!
Reason: clarification
