Old 07-13-2015, 11:52 AM   #11
JFP in PA
Originally Posted by PorscheFan5 View Post
JFP,
Attached are some pics of my DMFW before clean-up. Would you agree that it seems in good condition? I tested based on the testing procedure you posted. The twisting results in deveation of about 10-12mm. So that is good. It is identical on both sides.
However, the FW does not go back to the original position (center) when released after twisting. Please tell me that I don't need to get another FW... I am planning on taking the FW for balancing today. Hopefully you'll see this message and are able to respond.
Thanks!
The flywheel should return to its original position after being tested. If it does not, the elastomer is failing and the unit needs to be replaced.
