Old 07-12-2015, 11:07 PM   #2
leafdude555
The blue+gray wire coming out of the gauge through the blue connector is connected to the same 12V rail as the gauge backlights. You could try powering that blue+gray wire with 12V and see if it turns the bulbs on. Be careful because now you are applying power in the wrong direction since the gauge cluster powers that blue+gray wire to apply backlight to the centre console (radio, climate control, buttons, etc).
leafdude555 is offline   Reply With Quote
