Old 07-11-2015, 02:57 PM   #1
bryankberry
Hands are still greasy but I wanted to jump on and thank both of you (BoxsterSteve and 911Monty) very, very much!!!! That was the solution! When you both said check the spark plugs I thought, "that's an odd solution to what sounds like a major problem". But sure enough, the middle plug was loose. Tightened it down, started it up and noise was gone. If you both lived in Houston I would buy you a steak dinner. Thanks again!
bryankberry is offline   Reply With Quote
