Old 07-11-2015, 02:07 PM   #24
particlewave
Originally Posted by Myoung73 View Post
It's hard even to buy tires for the Boxster for $600 total not including mounting and balancing (which you will obviously do yourself). Not sure how you do all of that, even doing the work yourself, for $600 to $1000. Unless you just need brake pads and not rotors I can't see even getting the parts for that. But I'm new to this and certainly no expert.
That's apparent
Rear tires only and why would I replace the rotors simply because I need brakes? Rotors are fine (and even if they weren't, resurfacing is cheap), tires can be found for around $200 each if you do the research, mount and balance $10-15 each, and possibly a water pump...check your math.
Nice try, though. Keep at it
