You could check the temp in the overflow reservoir with a thermometer. Eventually the fans should come on to lower the coolant's temp. You've got to make sure the engine's being cooled since these engines are extremely sensitive to overheating. Use the 'search' function and keep on it or you'll find you have an intermix problem...
