Originally Posted by Topless
A couple questions.
What tires will you be running?
Do you have ROW M030 suspension now?
Adding the ROW springs will lower the car a bit and maintain proper rake and geometry. A lot of aftermarket lowering springs get the car too low and goof up the geometry causing it to have less grip and run slower laps. Not ideal for competitive SCCA AX.
I'm running rs3 2s this year. I'll switch to the re111s as soon as I can though. I'm also running the euro m030 springs shocks and rear sway. How much do you have to do to fix the geometry?
