Old 07-08-2015, 12:37 PM   #2
newBgeek
Originally Posted by pieter1 View Post
Gilles just a question if the relay latches (click) does this means it is working or can it still be faulty
No. A clicking relay does not mean it is working. I made this mistake when I replaced a radiator fan (checked the relay first to make sure it clicked at the advice of another forum thread) only to find that the fan was fine and the relay was the issue. ARRRRGGG!!! Then, a couple months later the other radiator fan failed (this time confirmed the relay actually worked before replacing). I replaced it with the fan a took from the other side, but it only lasted a couple weeks before it failed again. Double-ARRRGGG!!! Anyway, now I have 2 new fans, and I keep a spare relay just in case.
You can bench test the relay if you have a multi-meter, or just swap it with a known good relay.
newBgeek is offline   Reply With Quote
