Old 07-07-2015, 10:45 AM   #2
Perfectlap
Perfectlap's Avatar
2005 - 2008 failures are very rare in the Cayman or Boxster. Porsche revised the design of the bearing to be stronger but did so in a way where the bearing can not be serviced without taking apart the engine. Not an issue if you don't plan on driving the car a lot or keeping for a really long time. The bearing will probably outlast the engine if both are properly maintained and driven.
For 96-99 Boxsters, the IMS is not that big a deal since the it has two rows instead of the problematic single row. The dual row should however be replaced when the clutch is replaced to play it safe.
For Boxsters from 2000 (mostly) thru 2004 the bearing can also be replaced easily. So the issue is largely overblown now that there has been a way of addressing it for many years.
Your more likely concern engine wise are all the other ways an m97 engine an fail in a Cayman or Boxster just like the very similar m96 engine found in the first gen water-cooled Boxster and Carreras.
BORN: March 2000 - FINLAND
