Originally Posted by particlewave
I have some OEM amber LEDs and could make an LED "bulb" for you if you can do some soldering.
The bulb and holder are basically mated in a way that I can't just make an LED bulb that you could swap out. You would need to remove the holder/bulb assembly and solder the new LED directly to the contacts.
OR
If you can go for a week or so without the cigarette lighter light, remove you bulb holder and send to me so I can fit it with the amber LEDs. That way would not require any soldering on your part.
PM me if interested...no charge.
Sending to you sounds like the best option - I know my limitations and I tried soldering something once and it was a total failure, would prefer not to mess it up... I will pm you when I get it removed
