Old 07-03-2015, 02:10 PM   #4
911monty
911monty's Avatar
Originally Posted by Roxshot View Post
The temp was barely over the second "100" dash. It was a slow flash which, according to this post, means low coolant. Looking at the coolant level window seems to confirm that - it's just below the "Min" line.
How can I tell what the current coolant is? I certainly don't want to make goo!
Thanks for the info!
Well let me see if I can help. If you don't know what coolant you have then I recommend getting a sample from your tank, turkey baster will work. put in clear jar and look at color. Pink is Porsche factory color, Clear is Euro formula (Zerex G-05 ). Red is Japan long life and green is standard Prestone coolant. There are other brands but this is basic and should keep you out of trouble.
