Old 07-03-2015, 08:48 AM   #18
JFP in PA
Originally Posted by Jamesp View Post
And you work on these cars? Not mine if you don't even know that at TDC the lifters are sitting on the Cam circles and it is physically impossible for the valve springs to move the cams. I suppose you use two cam locking tools and the crankshaft zero lock along with bolting the flywheel end of the crankshaft to the block before changing an IMS?
Yes, I do work on these cars, and have been called upon to reset the cam timing on more than one three chain motor that jumped time when the owner removed the tensioners without locking the cams while the engine was at TDC. You should never pull the tensioners on the three chain motors unless the engine is locked at TDC, and the cam lock is in place. To do so is inviting a disaster.
