Old 07-02-2015, 05:25 PM   #2
JayG
On the slippery slope
JayG's Avatar
Yes. Use distilled water.
What was the temp when the light flashed?
Since you are in a cold climate and get sub freezing temps, you don't want top add a lot of water. A cup or 2 is fine. Beyond that , get some Porsche coolant and mix up some to top off your tank.
****** Warning******* do not mix different coolant types, make sure what ever you are adding is the same type as what is in there, otherwise you could make goo
2004 996 Targa Tip
Instructor - San Diego region
