Old 06-30-2015, 07:58 PM   #1031
particlewave
After some research and memory refreshers, I'm 99% sure that your headlight switch is cooked. You describe the exact symptoms of a bad switch, so that's where I'd start
Fuses A9 and A10 are the low beam fuses, so check those, but I doubt they'd both blow at the same time.
