Old 06-28-2015, 08:53 AM   #6
JFP in PA
Originally Posted by amagalla View Post
OK. I need advice. I'm at the point where I have the transmission out and I need to put the cam lock (LN engineering) for a 2003, 3 chain engine. I'm putting the cam lock into the cams on bank one behind the passenger seat (right side of vehicle for the RHD folks), but I can't seem to get it to go in. It fits in the bank to cams but not in bank one. This tells me that one of the cams on bank one is out of timing. It's only out by lest than one degree. is there ant way to fix this without having to put the whole thing back together?
Please help.
Tony
Try rotating the engine (by hand, clockwise direction only) another lap or two and see if the cam lines up then. What ever you do, do not attempt to rotate the engine counter clockwise.
